For a 3 phase system, is it possible to setup 3 standalone unit where each unit consists of 1 x multiplus and 20kwh battery and connect 3 of such unit together at the AC out side.
You want to run a three phase set up with a grid connection to a three phase set up?
Alot of how safe both inverter set ups are will depend on how you program them.
It is officially unsupported, but people do it anyway.
You can, but monitoring and controlling with one gx will be a challenge or impossible
Why not setup as a 3 phase system?
each will be an individual set. where it got its own Cerbo GX. and electrically it is connected in 3 phase. Is it possible?
Yes its is possible, a lot more expensive, not supported, but will work
As long as grid is there you will be fine if that is a three phase ev charger.
If there is no grid there is a likelihood that there coud be a problem with the phasing.
I think you are right. when no grid might have issue
