3 phase 127v Curaçao
Is it possible to use a victron 3 phase inverter as a 3 phase 127 volt inverter here on Curaçao? We have 127v/50 Hz. Is the AC part tuned with software (220 volt to 127volt)?
Have you looked at the available inverters? There are split-phase devices for the American market or transformers for universal use … 120V - 230V or 230 - 230 V
Is a 3 phase system necessary ???
The system of this house is a combination of 127v outlets and a dozen 235v outlets (that means two phases combined). The 235 (we call it 220v) is used for airco units, carpenter machines, the stove and several other parts. That goes on with the 110v.
So I need an inverter which give me 3 phases of 127v. I shall search on the American market.
Yes and let me explain why. I’m gonna install about 16 panels, a battery family (Pylontech) and of course an inverter. Than I want to go off grid. We cannot trust the grid of Aqualectra here on Curaçao.
Then you could use 3 multis/quattros in a 3-phase configuration. I would definitely keep a generator in the background …
You would have 3 phases 120V at 120° each as normal … or 2 phases 207V … whether that would be sufficient for your devices
You could increase the output voltage slightly to get your 127V.
You could simulate a multi 120V via VE-Configure … max is 128V
So I would say … that works
Depending on the electricity tariff / stability, you could go parallel to the grid and then recharge your batteries at certain times … So you don’t have to be OFF-grid all the time, but only when it’s necessary. I would almost favour this for large loads.
Or is there really no other way?
Then … lets go OFFGRID :grinning:
Hello, Yes this works perfectly well.
We make many systems here in Aruba.
regards, Rob
