I have a newly installed 3 phase Victron Multiplus II/5000 ESS with 4 Pytes 51.2/100Ah batteries.
According to the installation manual, the lowest battery should be the Master battery which is connected to the Cerbo GX.
The Cerbo GX also shows 4 online batteries. But the only active battery is the top one, the others are green blinking.
So you want them to discharge more? I think start with ess scheduled charge and get them to charge first then work out the rest.
Ok so not taking to the system is it on the ac in?
You will have to treat it like grid and set the inverter to charge up during solar hours or something like that unless you add a meter or a modification for it.
Hi, it seems normal. This might be due to a difference in state of charge between the batteries. Are the batteries providing enough backup time? If a battery is neither charging nor discharging, it will go into standby mode to preserve its energy.
