3.80~39 tank levels cut off
The levels page is getting cut off on the bottom
On the displays and in vrm remote console
V3.80~39
I’m experiencing the same issue as well.
Mine is fine. Do you both have physical screens on the GX?
No, I am not using a physical display connected directly to the GX device.
I access the GX device using a tablet via gxDisplay, as well as through VictronConnect and the VRM Remote Console on both Android mobile phone and PC. The issue is present in all cases, so it does not appear to be related to a specific display device or access method.
Just fyi for the levels page problem:
You’ve gotta let it sit on the level screen till it maximizes and hides the menu buttons.
Thats when it cuts off the bottoms.
Mine seems to behave in that scenario as well.
In my 2 Installations - i see the same on both installations with the missing part at the bottom.
Furthermore I receive alarm messages even they are switched off in the device management
I see this problem too.
Update to v3.80 42, but the alarm messages are still coming through. With V3.80 33, there were no uncontrolled alarm messages.
UPDATE: Levels page still did not get fixed with the new update 3.80~42
It is still getting cut off on the bottom when it enlarges.
Same problem in 3.80~44, including the tank alarm, which is not configured on restart
When a known issue is addressed it will be listed in the change log. I did flag this with the OS gurus. There have been a fair number of holidays going on this time of year, so they will no doubt get round to this.
This comes with the territory for betas.
Thanks for the reports.
The level page and the issue with the wrong level messages still not solved in v3.80 42. Went back to v3.80 33 which works without issues on my installation.
@dfaber could you please investigate?
The bottom cut-off will be fixed in v3.80~46.
Just tested v3.80~46 and can confirm it’s working correctly now. Thanks!
yes this topic is fixed but the not controlled messages of empty LPG is open- Will open a separate topic for this
