I’m working with genset connection (Dometic 4KW Genset) and Victron System.
Here the testing.
The first version was using the External transfer switch from @kwindrem and Modified Gui mods.
Switching to Gui V2 and 3.50 the package is not compliant.
So in the same way I using a transfer box giving the contact loop to digital input set as generator to after change the AC input status, and the AC current limit (75% of my genset maw power)
Here the final version, where I also remove the input view of the Shore or Genset but use a second digital input for.
A lighter version could be done by just swithching the AC input type from Genset to Shore or Grid on None and vice versa…
This one is in test on a fresh Cerbo MK II model and works since begining of August with the simplified version.
The latest verson has been implemented 2 days ago, seems to be OK, but I’m often checking the system.
The priority source is the Genset. If as my goal is to use the Shore the less than possible.
Xavier
