2x wiring to multiplus per manual
Getting ready rewire my rv with proper marin grade cables. Got 4 batteries BattleBorn GC2 100ah each underneath airstream interstate (exposed to elements). Will run equal length 2/0 cables to central bas bar. Then, and this is a question- cables to MultiPlus 12/3000. The MultiPlus manual recommens 2x two runs of 50mm2 cables… I thought to run just one 4/0 cable, was I wrong? Do I really need to run 2 sets of 2/0 cables from bus bar to MultiPlus?
Use 2x 2/0AWG cables. A single 4/0AWG has less cross-sectional area than 2x 2/0. And, a single 4/0 is a pain in the backside to run. And, unless you are experienced and have proper tools, 2x 2/0 cables is less prone to bad crimps than a 4/0 crimp.
It’s easier to see if we switch to sensible units.
4/0 = 107mm2
2/0 = 67mm2
2x 2/0 = 134mm2
1x 250kcmil (aka 250 MCM) = 127mm2. So, if you insist on running one DC power cable, use at least 250MCM to keep the voltage drop and DC ripple low.
You MUST fuse each 2/0 individually using 200A fuses.
This topic just illustrates why using 12V for anything over 2kVA is just a bad idea. RV manufacturers, especially “premium” ones, need to move on from 12V.
Are you familiar with the problems with Battleborn batteries? If not, take a look at Will Prowse’s data.
Yes, two connection terminals are provided on the Multi for distribution!
