I have aquired 2x 200w kings fixed solar panels and 1x Victron mppt 100/20 contoller . Can i run these panels in series or parallel to supply a 100ah lithium battery. Thanks
I have two of them on a 24V system in series. The voltage sits around 35V, and the current doesn’t go over 9A unless a cloud passes. I’m using a 100/50. I do upgrade this to run four panels on this charger during summer, too much shade atm. I usually get about 130W-140W max from each panel. I’m in Townsville, North QLD. On a 12V system, you should be seeing around 18A from both.
If you want to connect them in series, you’ll need to open up the Anderson and replace it with a single 50A style connector, or use a couple of standard double Anderson plugs and join them together. Another option is to cut them off and add MC4 connectors, but I don’t recommend MC4 unless you have the proper crimping tool. The current and voltage from these panels can burn or melt things very quickly if not done right.
Thanks very much for the info. cheers
