Last few days I have noticed the MPPT was dropping it’s charge to around 40W during the middle of the day, normally this is around 700w from the two Longi panels and is maxing out the 50A MPPT limit.
I thought it was something wrong with the solar panels but checked and there was plenty of sun available at round 981 w/m2.
I then noticed the MPPT was going into float mode before the batteries are charged, tried two different battery banks and when both got to around 70% charge if would go to float, nothing has changed from my side on the MPPT before it started doing this, I did an update for the MPPT a few days ago but it mentioned it was only for Bluetooth.
I physically disconnected it as I thought it was a time out thing and it charged in bulk for a about five seconds then goes straight into float, obviously it’s hitting a voltage limit somewhere.
MPPT is set to rotary switch position 7 - Smart Lithium (LifePo4).
So the only thing I can see is to go to “User Defined” or “Expert mode”, but not sure what to set the various settings at for either setting.
Any help to get the right settings ?, what would be the suggested settings.
Below are screenshots of the settings available, thanks for any assistance.
At over 980 w/m2 I was only getting 48W
Below is User Defined settings
and Expert settings.
