Wiring guide help
hello i have purchased the parts my Victron person sent me.
now i need to buy all the connecting parts.
to do this i need to know the basic setup.
i have
Multiplus Inverter/Charger 2-3kVa
400W Solar Panels x 2
50A MPPT Solar Controller
Orion XS1400 for alternator charging
Orion 24-12-30 DC Converter for 12V Output
Smart Shunt battery monitor
Cerbo GX with Touch Screen
Battery
i intend to get 2 x 24v life04 batteries.
what fuses and bars etc do i need to purchase.
i would have thought that victron would have software for this.
i have an auto electrician to make cable connections and install it i just need to have the parts available so as not to waste his time.
Shane
Why not ask your “Victron person”? Much of what you are asking is in the product manuals. Much of it is stuff you should have figured out before you decided to purchase thousands of dollars in professional grade electrical equipment. Furthermore there is an abundance of posts on this site about fuses and busbars.
Sorry to be snarky but this forum receives these kind of requests constantly. This is all stuff a diligent DIYer can accomplish but please don’t ask professionals who have put thousands of hours of effort into understanding this stuff and make their living doing it things that are easily accessible in the book that came with your product.
https://community.victronenergy.com/t/frequently-asked-questions-and-commonly-encountered-issues-with-diy-installs/377/3
Sorry to offend you.
There is plenty of guidance out there on each product page.
Because the system and components are so flexible in design it requires a lot of work to design the system at a wiring level.
For the mppts.
A short Google for each of the other things and their product pages will have manuals at the bottom each manual has a fuse and wiring suggestion depending on cable run length.
But bars are also easy. They are sized on the amps expected to pass over it and number of connections needed to it. And of course where in the system they are being placed. Since it is a vehicle there will probably be a few in different areas link close to the inverter and some possibly in the engine bay.
It will all depend on the approach taken by the installer.
