Hi Community
In the VRM forecast I can see clear distinction between solar-to-battery and solar-to-consumption values.
In the past data it is combined to solar-to-consumption.
Is it expected or I have something set up wrong?
Since also your nightly consumption is shown as “grid 2 consumption”, that could only mean, your system is not configured correctly to conclude the actual energy beeing taken from the battery (or going into it). So, since the amount of consumption stays the same, it is assumed to come from grid or solar directly, rather than from the battery as predicted
What kind of battery / bms are you using? how is it connected to the gx?
OK. Found the solution based on other topics on this forum. Posting here as it might help others.
Disable “Display DC Loads” in GX Console (Settings → System Setup → Display DC Loads)
Now VRM shows historical data (since this moment) properly categorized
