Which voltage / amperage to use for my array math?
Hi All,
Dumb question about solar panel math… Use this panel as the example…
it’s a “100W 12V” panel… but that is or is not 100W when running at 12V (and thus 8.33A)?
The specs seem to say max power 100W is at Vmp of 20.7V and Imp of 4.84A (20.7V x 4.84A = 100.2W).
So if it’s actually running in full sun, optimal alignment (at STC, etc) then it’ll be doing 20.7V?
And if it was not full sun and chugging along at 12V then what’s the current? Still 4.84A (thus making 58W) or is it some smaller amount of amps, and if so, how many?
My point here is what V and A do I do my array sizing math with?
Thanks,
Toby
PLEASE, do yourself and the MPPTs a favor, go for panels with at least double the voltage.
Then the tracker will always get the most out of your panels.
And try to get the largest possible panels, every connection saved is a problem less.
The victron app mppt calculator explains the rest.
Have fun
15.7 % efficiency ? you got do be joking :anxious_face_with_sweat::scream:
Every solar panel will (should) have a datasheet with the voltage/current/power curves.
This graph is from 1 of my solar panels.
It also includes variation from STC (standard test conditions @ 25c) solar radiation (insolation).
Insolation varies with cloud thickness, and/or panel to sun angle.
Panel current varies with insolation %.
Panel voltage varies with panel temp.
The power calculation would be.
( Imp x insolation % ) x ( Vmp @ panel temp )
Easy.
Dont forget the panel Vmp has to be a minimum of 5v above the battery voltage.
I’m planning to run a hybrid array — 2 arrays wired to the controller in parallel, each array being made up of 2 panels in series. I figure that gets be 40V at 10A at the controller.
But that depends on my initial question about doing the math…
As you can see from the graph above, as the light level falls, Vmp reduces very slightly, the main change is in Imp. For a first order approximation, assume Vmp is constant and Imp is proportional to the radiance. So for your panel it will always produce around 20V but if the light is half as powerful then the current will be around 2.4A so power = 48W.
Yeah, they’re thin-film / flexible panels. I don’t have a choice on that given my application (camper roof).
Thank you, perfect answer!
ok,didn’t want to be rude …I thought thin film have already gone better in terms of efficiency …Best regards,Frank
