I have a Pylontech battery that has been unused for a couple of years, with a terminal voltage reading of 49V, indicating it is in good condition. I’d like to repurpose it for use with a Multiplus inverter in a UPS configuration. Could you advise on the best inverter size to pair with it—Multiplus 1200VA, 1600VA, or 2000VA?
Additionally, I plan to integrate a Cerbo GX for system communication and a SmartSolar 100/20 charge controller. Can you confirm compatibility and any recommendations for optimal setup?
