Advise on which mppt size required.
System is
Solar panels Panasonic VBHN330SA17 (330watt) number x 4 in parallel
Battery bank 6 x 48v pylontech UP5000 lithium. 30kw total
Thanks in advance
System is
Thanks in advance
Please try the MPPT calculator on the Victron website.
the Vmp of these panels is too low to charge a 48v battery, the VMP is 58V, it is barely enough to start the mppt (start voltage is bat voltage + 5V)
if you use your panels in parallel it will charge very badly if at all.
rather connect them 2s2p and a 150/35 MPPT will be sufficient.
