Where to buy GX Tank 140 terminal blocks
Anyone know where to buy the tank 3-pin terminal blocks for the GX Tank 140? I misplaced the bag I had with three remaining terminals.
Pretty sure those are Phoenix Contact FMC 0.5 but double check the pin pitch if its actually 2.54mm
https://www.phoenixcontact.com/de-de/produkte/leiterplattenstecker-fmc-05-3-st-254-1821106
FYI, I ordered these from Amazon and they seem to be the right size/pitch, so 3.5mm:
20 PCS 3 Pin 3.5mm Pitch PCB Screw Terminal Block Connector, Male Plug for 28-16AWG,Pluggable Quick Connector-3 Pole
