Weird startup issue
I have very recently had all my boat batteries rewired with the installation of a bigger inverter and separate centaur charger that also links to a separate DC to DC charger.
The weird part is that the centaur doesn’t start charging until I’ve turned it on, off, on, off and then on.
What could be causing this? :rofl:
do you mean you switch on 3 times, disconnecting and reconnecting the AC circuit breaker? because the Centaur itself doesn’t have a switch on the chasis
