Could be different battery banks have different settings, but currently no capability to validate this via original BMS wifi access
Solution ( workaround )
By reducing DVCC voltage to 54.5(and after some time to 55.9V) system behaves almost propely, without BMS locks charging, but can’t reach 100% ( stays on 99% of SOC )
I solved this issue by setting DVCC voltage to 55.4-56.4V and system works pretty ok
End up one of the batteries in setup has different parameters than others ( different manufacturing seasons ) which was confusing a system
I thought it might be an unfinished balancing of the cell voltages. What is your setting for the absobtion time?
Battery blocks of different ages can possibly cause problems due to different internal resistances during absorption. This could lead to an effect as described in the troubleshooting section 12.
