Did anyone measure the starting current of modern washing machines?
I’m using an LG 7kg direct-drive motor machine. The current and power readings on the sticker are controversial.
So need help. Maybe someone can measure it with an oscilloscope while washing not heavy load on a newer 4-7 kg size washer.
I wonder if I can harm my MultiPlus || 3000VA when
12BTU Midea conditioner and the 7kg washer working simultaneously.
Indeed, the heating element is the worst consumer in a washing machine. Although, its PF=1 is helping somehow.
Now, with the new regulations, its heating element will not draw more than 1-1.5kW.
And an 12K BTU will draw about 1-1.2kW when working.
So add those and you’ll be awfully close to the limit of the 3000VA or 2400W how the MP2 is declared.
