I have a gestion regarding VRM and Node red data. I´m looking for grid usage. VRM shows last 90 days data, 24,6kWh direct use and to battery 27.8kWh. Okey, If look VRM API node, It show grid to consumption (=direct use) 12.3kWh and Grid to battery 15.9kWh. Both VRM have same “settings” Start -12weeks and end now. Please see attached pictures. So, which one is the correct, or do I understand this wrong…? Thanks.
12 weeks (84 days) is not longer than 90days?
I found those figures confusing as well in anycase. Not sure if the rounding works differently as well.
