Hi, just switched to a Victron BlueSolar PWM controller and a bit confused. From my 120w solar panel on my campervan I have an output of 21v as measured on the cables into the Controller. But on the PV Voltage display its only shows 12v. I though this should show the panel voltage or am I misunderstanding something? Thanks
Chester_Steve
(Stephen Spall)
1
water_rat
(klim8skeptic)
2
When charging, the pv voltage will be similar to the battery voltage.
Have a read of Which solar charge controller: PWM or MPPT?
Related topics
| Topic | Replies | Views | Activity | |
| Smart solar MPPT controller showing PV voltage lower than it is | 4 | 782 | 8 November 2024 | |
| Battery not charging voltage difference from wires to controller | 3 | 153 | 20 January 2025 | |
| 120W solar panel on a 5A PWM | 9 | 152 | 24 April 2026 | |
| Blue solar charge controller not charging | 2 | 152 | 23 April 2025 | |
| PV charger Watts | 1 | 58 | 13 October 2024 |
