@victronenergy/node-red-contrib-victron No node for heat pump
Have fitted a ET112 to my heat pump and connected it to my system.
if I set it as a AC load I can see the data with a node red AC load node.
However when I set it as a Heat Pump there isn’t a heat pump node with 1. @victronenergy/node-red-contrib-victron
I presume this will be added ?
Hi David
maybe a bit late, but you can always use the Custom Input and Custom Control nodes to access the D-bus directly. This works quite well for me.
