Hi there,
we use some MPPT 75|10 to enable solar powered and unattended surveys to collect environmental data in a long time monitoring project.
Our devices are android based and do their schedule with Tasker automation routines.
To get more freedom concerning charging the device, we would highly appreciate if Victron Connect had an API to turn the MPPT’s load jack ON / OFF by sending intents via the app’s API.
Furthermore, we’d like to read out battery status via an API also.
So, is there a way to remotely access the MPPT 75|10 via commands sent / received by an API?
If not, maybe VictronConnect developers could implement an API in one of the next releases? Implementation e.g. as a Tasker Plugin is easy, I could send You any needed Info given from Tasker developer Joao Diaz himself.
I am sure that a lot of technically interested people out there would welcome such an interface to use automation tools such like Tasker or MacroDroid, because it could significantly expand the possibilities of home automation.
Thx in advance,
Stefan
