I’m confused how I need to ground the Orion DC to DC charger in my camper van. Can the single ground connection on the device be connected directly to the chassis? The diagram made it look like maybe I should ground it directly to the house battery and to the chassis both. I use a LYNX Distributor for grounding so this would mean I connect it to the chassis and to the Lynx distributor (which connects to the battery negative and chassis). Can that introduce a ground loop (other devices could reach the chassis in multiple paths–through the distributor or the DC to DC connection to chassis.
Can I just either ground the DC to DC Charger to the chassis directly OR to the Lynx Distributor–but not both? If so, which would be better?
Interesting, because when I visited DESY (the electron synchrotron in germany) all the conductors along the accelerator ring were made solely from aluminium.
And about 3 times the conductivity of steel… so for using it as a ground in a car chassis it’s maybe better…?
Possibly… but I would guess it was about price and that you find more people with certification to weld Aluminium… which likely are things to keep in mind when you have to build multiple 100+cm² bus bars that run for 6+km in total length…
