I have removed Fronius, keep the conf as basic as possible, I’ve the Virtual Switch but I think I will remove it.
LX, do you know how to tune the Parameter (1), I need it to let the (2) be as close to 0 as possible (within certain parameters of course).
If it is possible via command line (SSH) it is perfect, if I need to configure MQTT probably I will do that.
Maybe I should write on another forum section.
I am sorry i didn’t see your reply.
If you are modding now with your own code it is better to ask a new question.
In all honesty it is the best way with your type of set up.
There is a way to ignore ac in using the generator control on the GX of you do not want to ssh or use other deeper methods.
Basically wire the gx relay to the aux/temp and use the aux to switch the primary relay.
Ciao LX, I’ve dove everything externally (Home Assistant + NodeRed), it works really well.
