Ola i need the Option to Cascad 2 Ess systems like Master Slave (Slave 2 …) the Option to Make on ESS and the second Micro grid so it is connected to the Master by AC IN please implement a Way to Sync somehow the ESS 1 With ESS 2 etc.
1. Pac is a 3Phase 9X MP2/48/3000 (27kva) and the Second ESS 3p 3x MP2 48/15000 (45kva) both have Grid in use to be fare i want to have Still the Option but if connectet the Batterie Discharge (aka SOC) should be regulatet faire between the 2 Systems ( connected by 350m 5X50mm2 aluminum) its all about Master Slave System config different SOC settings should be added like SOC AC in SOC AC OUT to Balace the single System to perfection thx
