Hi @RoarPowerNZ
When connecting to a Cerbo, there are other problems with the bluetooth stack on the Cerbo that are causing problems. This should already be much improved in the beta firmware version.
With kind regards,
Thiemo van Engelen
Hi @RoarPowerNZ
With kind regards,
Thiemo van Engelen
If I turn on “Beta release” on my raspberry pi units, will i get the firmware you are referring to?
If so, i have about 6 i can do, and test the bluetooth process and report back.
Hi @RoarPowerNZ
When you turn on “Beta release” on the raspberry pi, you will indeed get the firmware that should improve the bluetooth behavior of the GX/Venus firmware.
With kind regards,
Thiemo van Engelen
I am also having an issue pairing a Pixel 8 with Android 15 to Smart Shunt and Smart Solar. It appears to be the same as others reporting here, including the video robnelson posted on March 26. I do not have TopDon or Eebms “Solar Guardian” on my phone. I turned my old phone, a Pixel 4 with Android 13, back on and it is still able to connect to both Smart Shunt and Smart Solar. I have seen elsewhere that Is there a specific issue with Android 15?
Not generally, seemingly only in connection with pixel.
