Victron combination to grid
Hi all, I have recently installed a Victron system comprising of:
  1. Victron 8kva Multi II
  2. Cerbo GX
  3. Felicity solar 48v 250ah
  4. Smart solar250/70
  5. 3 X sharp 580w bifacial
One use case I tried to fulfill was that if the power demand is higher than e.g. 5000 I would like the 5000w to be serviced by Victron and the rest from the grid. For example I have the cooker on= 3000w and the water heater= 4000w so a total of 7000w so I wanted the 5000w to be provided from victron and the remaining 2000w from the grid.
However testing this ended up as soon as the power demand surpassed the 5000w, victron activated the passthrough and allowed the full 7000w to be serviced from the grid.
Any ideas if what I want to do can be accomplished?
Thank you in advanced .
Normally, “Power Assist” works the other way round. The shore power is supported by the battery and not vice versa.
So if your shore connection is limited to 10A, for example, the Multi uses the battery at higher loads …
Your battery would also be too small with a typical 100A discharge current.
Do you get a warning from the battery / BMS?
Hi and thanks for your feedback,
The full story is that the victron is connected to a netmetering system that comprises ofn
  1. A fronius gen24 plus
  2. A BYD HVM 11.04kwh
  3. 4.92kwp of solar.
Currently I am treating the grid (and the fronius system which works in parallel) as a generator.
I have relay 1 activated either on demand or every day at 10am and leave it open for an hour and a half.
Relay 1 mostly works as passthrough with a 5amps charge of the battery.
I can also activate relay 2 for additional charging power of 40amps. Relay2 works only if relay1 is open.
What I want to do is maximize the usage of solar so the way I thought about it was to have the victron service power demands up to 1740w (Which is the pick power of the solar panels) and transfer the rest of the demand to the grid (which in my case will prioritize the fronius).
By the way maybe power assist woukd also work. I would prioritize grid (Fronius system in my case) to service power demand of 3000w and from then on supplement with Victron.
Can I do such a parameterization through Cerbo GX or do I need to access the multi directly ?
Then you could only solve the whole thing via a “virtual contact”. In this case, the multi remains disconnected until a certain power is called up … You can use several Set conditions.
Adjustable via VE Config …
So this means opening the Multi and using the mk3 usb ?
So my understanding is that Prioritizing the Victron until a certain power demand is reached so the grid is connected cant work, correct ?
Why do you want to open the Multi to connect the MK3? You could also change the setting via VRM remote configuration … so no MK3 … and no opening of the Multi
Great, I am completely novice so guessed the mk3 was needed
Your solution does not work when the network is connected. Here you would always try to save the battery. You could set an input current limit … but that would not solve the problem …
So only with a virtual switch and thinking the other way around …
If your system is registered in VRM, this can be done via the remote configuration.
but of course you need VE Configure …
After editing … SAVE … then upload … Done
Thanks, I really appreciate your feedback!!!
With pleasure
You can also simulate a device to see what would be possible with the “VC”.
Are you sure the battery is not shutting down? Looking at the spec sheet, it can only do 120A and has a shutoff voltage of 48V. It can do 150A for 15 sec. Are you able to install the ESS assistant? There is a setting to limit inverter power and the rest comes from the grid.
Why not use it as grid connected ess? That will also do what you want
The installer said that the ess is used mostly for feeding power to the grid. That is why it hasnt been installed.
I will read about it and will revert back
The ESS is used to use as much solar yield as possible to cover the grid load. In the ESS settings you can simply set the value for the maximal inverter power to 5000 W, or to any other value.
No is not for just feeding into grid, its like Tomberger said, to use as much pv/battery as possible/required
See:
Hi all and HAPPY EASTER!!!
I thought of another way to combine the full power of Fronius (which is around 4800w) and the Victron Multiplus II 8KVA.
Currently I am using the Grid (which means the Fronius) as a generator. Victron will switch to the generator if one of below 3 conditions apply:
  1. If the Battery SOC is below 25%
  2. If power demand on the Victron inverter is above 6550w.
  3. At certain time of day and for certain period to charge the battery.
So what I am thinking is the following:
I leave the victron parameter 2 as is, which is 6550w
I change the Grid Current Limit to 19.5 amps (which is 4485w)
This will mean that as soon as the power demand is e.g. 8000w then Victron will passthrough to the grid the 4485w and will service the remaining 3515w from the battery.
Is my understanding of Power assist correct?
Currently the Assist boost factor is 2.0 does that play any role?
And one last question is can the Grid Current Limit vary depending on conditions?
Thank you in advance for any help
