i think simple one but i cant find an answer yet the charger has three outputs and you select what technology the charger should use , if you have three different types , standard lead starter battery and two lithium leisure batteries is it best to select lithium or standard as it appears only one technology can be used at one time
Related topics
| Topic | Replies | Views | Activity | |
| Victron Energy Blue Smart IP22 12-Volt 15 amBluetootp 230V, Caricatore Batteria a 3 Uscite CEE 7/7, | 0 | 29 | 3 March 2026 | |
| IP65 12v 15A Blue Smart Charger | 1 | 125 | 9 January 2025 | |
| Advice: Blue Smart IP22 Charger 12/30A (3) VS Smart IP43 Charger 12V/30A (1+1) | 3 | 441 | 11 June 2025 | |
| Smart BMS 12/200 with Easy Plus 1600 and Victron Smart LiFePO4 12,8V 200Ah | 1 | 77 | 19 May 2025 | |
| Does Victron Make any Two-Way B2B Battery Chargers? | 13 | 586 | 10 August 2025 |
