Venus v3.60~66 - High current alarm - BMS setting lost/set to zero
Running the Venus v3.60~66 version and regally I get the alarm message: “Battery Monitor - HoekHuis Battery1 [512], High charge current alarm: Alarm” The BMS communicates (to my understanding the max charge/discharge values to the Victron system. The BMS is set to 50A for bother parameters. This is converted into 47.5A in the BMS parameters settings (with marge). But as you can see in the screenshot I sometimes get 0 for the CCL/Charge Current Limit which results into an alarm message. Any suggestions on how to solve this ?
In the Multi RS Solar the max charge current is set to 100A, max discharge current is disabled and DVCC is enabled.
