I noticed that the Temperatur Levels Go Up to a Maximum of 60 degrees in the Schale, but my storage Always reaches 85 degrees. Maybe a Display Up to 100 degrees would be more sensible.
Temperature type Water Heater goes up to 100degC since V3.60. Type generic may also do the same but I am not sure.
This IS My, and you can See IT IS max.
the display works, but the akala does not
Generic goes to 60 max I use them for the temperature of my pv inverters that exceed 60.
