V3.62 showing incorrect AC Load value in split-phase setup
After upgrading from v3.60 to v3.62 my VRM started working - thanks for that! But now I get occasional incorrect AC Load values on L2.
When I switch back to v3.60 I get the correct values. When I switch back to v3.62 the values will be correct for a while.
Normally my idle AC Load is L1=200W to 300W and L2=100W to 200W. Eventually in v3.62 it will report my L2 to be between 600W and 900W. Which is about double my total AC Load at idle.
Can you confirm what your GX device is? Do you have any mods loaded (you can check in settings- general - modifications)?
Cerbo GX. Venus Large. Nodered enabled. Added dashboard. Have not started using dashboard. No mods. (Do not know what those are yet.)
My nodered flow disconnects from grid on weekdays between 7am and 9pm to run from battery when the rates are higher. Right now grid is connected battery is 100% and showing 0W.
It sounds similar to the issue I am having. See:
I will try to roll back to 3.60 and see how it behaves.
What kind of grid meter do you use?
I use Victron ET340, and its been working fine for 2 years , until just now.
Phase assignment is still correct. The 0W was what was going into the battery since it was at 100%.
