V3.60 grid setpoint not working
Yeah, that is one of the limits the Scheduler is unaware of.
If you restrict feedin locally to 3200, you need to set the maximum grid export in vrm → Dess Settings to 3200 as well, else the scheduler has no idea of that.
If you do that, it will only schedule with a maximum grid export of 3200.
OK, I’ll test that in the DESS settings.
On my previous messege - what made the GX pull from the grid? Is it the calculated and preset “Dynamic ESS”>“Target SOC”? This way of ragulating the system realy is prone to errors.
Keep an eye on that, once you fixed the settings. When the scheduler has an actual idea of your system beeing limited to 3200 export, the whole schedule and calculation will be different and most likely not result in that large differences leading to undesired behaviour.
You almost had 15% more soc there than the scheduler was predicting.
