Installed ~66 today, but getting grid overload alerts, never received them before…
Update 30-04: today the issue appears again during battery discharge to grid:
hi @JeroenSt , you are most likely running DESS?
Then we recommend to setting the setting for VE.Bus alarms & warnings to alarms only.
under DESS its normally / wanted to run the device at full power now and then.
where for other types of usages (off-grid mostly) its a bit different.
here is the setting:
best regards, Matthijs
Hi, no thats on VRM, doesn’r affect what you see in the new, nor the old-, UI.
I’ll ask someone to check
I’ve noted that UX issue btw - thanks.
