As in v3.60~53 (and perhaps even before), the custom shape points of a tank cannot be deleted in gui-v2. In gui-v1 it works fine.
thanks @PF_1 , we’ll look into this
I can delete my custom tank points but only set them up to get around a sensor (that per the manufacturers recommendation on a waste tank) that the sensor not go all the way to the bottom of the tank and Victron’s O% & 100% are implied rule. I wanted to just delete this whole custom setup or change to rectangular but appear to have no options for either.
Hi both, fixed per v3.60~69.
Thanks again for the report!
And if you can please test and confirm back
Thank you for the perfect solution as always.
I am happy to confirm that the custom shape points can now also be deleted again in gui-v2
