V3.60~46 PV Inverter: PV limiting, although deactivated in the settings (SolarEdge)
if I say in DynESS that feed-in is not permitted, DynESS limits the PV inverter production so that zero feed-in occurs. So far logical.
However, this also happens even though I have deactivated ‘Dynamic Power Limiting’ in the PV inverter settings. I am using the SolarEdge SE7K.
This has happened in the past and should be fixed.
I have therefore currently deactivated DynESS.
By the way: I use the above DynESS setting as an emergency solution so that the DynESS does not discharge my battery into the grid in the morning, although the feed-in tariff is very low throughout the day and is far below the electricity price. Due to the losses, discharging into the grid makes no sense. Unfortunately, you can’t activate the charge and discharge restriction from and to the grid at the same time.
Goodbye
Dirk
