I just updated to v3.60~23.
Unfortunately there the switch for feed-in limit is activated. But I never used this feature because I don’t need to limit feed-in. It’s not possible to deactivate the switch. Limit value was set to 0W and last line says that limit is not active at the moment.
If I set the value to 12.000W for example it is said that the limit is active at the moment. But it’s dark outside now. If I click at the switch again the value is reset to 0W and it’s said that the limit is not active now. But the switch itself stays activated. Or maybe only the visualisation of the switch has a bug?
Is this a repeat post?
Did you not see the reply?
All in beta. So really all related.
Oh, sorry, I forgot that I posted this for v3.60~20 already. So this is just a reminder that it’s still a bug at v3.60~23.
