I found my solar would still power anything 12 volt connected to the Lynx distributor as it is downstream of the remote relay. I use this double pole switch to disconnect the solar and relay at the same time with good results. You can see it in the first picture here.
Related topics
Topic | Replies | Views | Activity | |
SmartSolar MPPT 100/30 voltage high when Lynx BMS is off | 3 | 44 | 10 June 2025 | |
Bms v2 - dvcc & mppt issue | 10 | 133 | 6 June 2025 | |
MPPTs throttling down solar once charged voltage reached | 10 | 219 | 27 June 2025 | |
Generator not being prioritized, over Alternator, after v3.53 update | 12 | 101 | 21 April 2025 | |
Sanity Check -- Component Integration | 8 | 92 | 21 August 2025 |
