Using MPPT 75/10 load not shown on remote console only PV and battery
I am setting up a small system for a microwave site. I have it all up and running
The charge controller is an MPPT 75/10 The system uses an RPi with VenusOS running on it. I have other sites with similar setups.
The remote display (web based) shows both the PV source and the battery but it does not show the charge controller for some reason. On my other systems I am using Smart Shunt but this system is quite small so the LOAD output of the MPPT 75/10 is more than sufficient for the operation.
But even though I can go into the remote screen and see the entry for LOAD, it does not show load as part of the display screen I have GUI Mods loaded in which corrected the PV source not showing up, but regardless of what I do I cannot obtain an indicator for the load.
Has anyone else run into this issue?
