Hi all, has anyone had experience using a Phoenix 12v to 230v 3000 VA smart inverter to run a Karcher K5 HP water cooled 2.2kW induction motor pump used in a water maker that only causes the pump to draw 1.1kW. 800PSI instead of 2400PSI. The pump will use a set start. Is this easily achievable with the Phoenix and will it have good longevity with this configuration?
Regards Jack
