Usb nmea gps on node red
Hello, I want to create a Node-RED flow with the GPS position. I have an NMEA GPS connected to my Cerbo GX, but I cannot find it in Node-RED. Any help?
Thx
If the gps is connected and visible on the gx display, then try using the custom node in node red to retrieve the data from the gps on dbus.
I have a GPS connected that is visible in the remote console settings menu but not appearing in the Custom node under GPS. What can I do about that ? I’m ultimately looking for the GPS time to be available when internet is down.
It’s been a very long time since I’ve used node red on the cerbo so take this with a grain of salt. I think there is a victron input gps node, select utctime as the measurement/value. If that doesn’t work you can always use mqtt and subscribe directly to the utctime topic.
There is indeed a gps node but time is not there among the measurements available. Also in mqtt /gps has not got time.
