here is how i solved it:
[{“id”:“f9b7078128f9a26d”,“type”:“tab”,“label”:“GPSD”,“disabled”:false,“info”:“”,“env”:},{“id”:“9f3fbd58af4317a6”,“type”:“function”,“z”:“f9b7078128f9a26d”,“name”:“Map to dbus paths”,“func”:“// Array to hold all messages\nlet messages = ;\n\n// Process position data\nmessages.push({\n path: ‘/Position/Longitude’,\n payload: msg.payload.lon\n});\n\nmessages.push({\n path: ‘/Position/Latitude’,\n payload: msg.payload.lat\n});\n\n// Process other GPS data\nmessages.push({\n path: ‘/Speed’,\n payload: msg.payload.speed\n});\n\nmessages.push({\n path: ‘/Course’,\n payload: msg.payload.track\n});\n\nmessages.push({\n path: ‘/Altitude’,\n payload: msg.payload.alt\n});\n\nmessages.push({\n path: ‘/NrOfSatellites’,\n payload: msg.payload.satellites\n});\n\nmessages.push({\n path: ‘/Fix’,\n payload: 1\n});\n\n// Return array of messages\nreturn [messages];”,“outputs”:1,“timeout”:0,“noerr”:0,“initialize”:“”,“finalize”:“”,“libs”:,“x”:550,“y”:320,“wires”:[[“d0ab1fd887ba1713”,“e7809df1cd0c1413”,“7d1041511b6b6713”,“fbe5647a887a087e”,“85002e6b0dea51d3”,“e56df79b2013ced9”,“d9dd532920f06638”,“03130173681b8084”]]},{“id”:“99e2c63fa141341a”,“type”:“gpsd”,“z”:“f9b7078128f9a26d”,“name”:“GPSD-Server”,“hostname”:“192.168.2.11”,“port”:“2947”,“tpv”:true,“sky”:false,“info”:false,“device”:false,“gst”:false,“att”:false,“x”:70,“y”:320,“wires”:[[“387fb997123921d3”]]},{“id”:“d0ab1fd887ba1713”,“type”:“debug”,“z”:“f9b7078128f9a26d”,“name”:“debug 1”,“active”:false,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“false”,“statusVal”:“”,“statusType”:“auto”,“x”:800,“y”:260,“wires”:},{“id”:“14f79ecb75d257a1”,“type”:“victron-virtual”,“z”:“f9b7078128f9a26d”,“name”:“GPSD-Server”,“device”:“gps”,“default_values”:false,“battery_capacity”:25,“include_battery_temperature”:false,“grid_nrofphases”:1,“include_motor_temp”:false,“include_controller_temp”:false,“include_coolant_temp”:false,“include_motor_rpm”:true,“include_motor_direction”:true,“position”:0,“pvinverter_nrofphases”:1,“fluid_type”:0,“include_tank_battery”:false,“include_tank_temperature”:false,“tank_battery_voltage”:3.3,“tank_capacity”:0.2,“temperature_type”:2,“include_humidity”:false,“include_pressure”:false,“include_temp_battery”:false,“temp_battery_voltage”:3.3,“x”:70,“y”:400,“wires”:},{“id”:“3dc5d1252704f8a3”,“type”:“debug”,“z”:“f9b7078128f9a26d”,“name”:“debug 2”,“active”:false,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“false”,“statusVal”:“”,“statusType”:“auto”,“x”:520,“y”:260,“wires”:},{“id”:“e7809df1cd0c1413”,“type”:“victron-output-custom”,“z”:“f9b7078128f9a26d”,“service”:“com.victronenergy.gps/100”,“path”:“/Position/Longitude”,“serviceObj”:{“service”:“com.victronenergy.gps/100”,“name”:“GPSD-Server (100)”},“pathObj”:{“path”:“/Position/Longitude”,“name”:“/Position/Longitude”,“type”:“object”,“value”:null},“name”:“”,“onlyChanges”:false,“x”:900,“y”:320,“wires”:},{“id”:“d9dd532920f06638”,“type”:“victron-output-custom”,“z”:“f9b7078128f9a26d”,“service”:“com.victronenergy.gps/100”,“path”:“/NrOfSatellites”,“serviceObj”:{“service”:“com.victronenergy.gps/100”,“name”:“GPSD-Server (100)”},“pathObj”:{“path”:“/NrOfSatellites”,“name”:“/NrOfSatellites”,“type”:“object”,“value”:null},“name”:“”,“onlyChanges”:false,“x”:890,“y”:620,“wires”:},{“id”:“e56df79b2013ced9”,“type”:“victron-output-custom”,“z”:“f9b7078128f9a26d”,“service”:“com.victronenergy.gps/100”,“path”:“/Altitude”,“serviceObj”:{“service”:“com.victronenergy.gps/100”,“name”:“GPSD-Server (100)”},“pathObj”:{“path”:“/Altitude”,“name”:“/Altitude”,“type”:“object”,“value”:null},“name”:“”,“onlyChanges”:false,“x”:870,“y”:560,“wires”:},{“id”:“85002e6b0dea51d3”,“type”:“victron-output-custom”,“z”:“f9b7078128f9a26d”,“service”:“com.victronenergy.gps/100”,“path”:“/Course”,“serviceObj”:{“service”:“com.victronenergy.gps/100”,“name”:“GPSD-Server (100)”},“pathObj”:{“path”:“/Course”,“name”:“/Course”,“type”:“object”,“value”:null},“name”:“”,“onlyChanges”:false,“x”:860,“y”:500,“wires”:},{“id”:“fbe5647a887a087e”,“type”:“victron-output-custom”,“z”:“f9b7078128f9a26d”,“service”:“com.victronenergy.gps/100”,“path”:“/Speed”,“serviceObj”:{“service”:“com.victronenergy.gps/100”,“name”:“GPSD-Server (100)”},“pathObj”:{“path”:“/Speed”,“name”:“/Speed”,“type”:“object”,“value”:null},“name”:“”,“onlyChanges”:false,“x”:860,“y”:440,“wires”:},{“id”:“7d1041511b6b6713”,“type”:“victron-output-custom”,“z”:“f9b7078128f9a26d”,“service”:“com.victronenergy.gps/100”,“path”:“/Position/Latitude”,“serviceObj”:{“service”:“com.victronenergy.gps/100”,“name”:“GPSD-Server (100)”},“pathObj”:{“path”:“/Position/Latitude”,“name”:“/Position/Latitude”,“type”:“object”,“value”:null},“name”:“”,“onlyChanges”:false,“x”:890,“y”:380,“wires”:},{“id”:“03130173681b8084”,“type”:“victron-output-custom”,“z”:“f9b7078128f9a26d”,“service”:“com.victronenergy.gps/100”,“path”:“/Fix”,“serviceObj”:{“service”:“com.victronenergy.gps/100”,“name”:“GPSD-Server (100)”},“pathObj”:{“path”:“/Fix”,“name”:“/Fix”,“type”:“object”,“value”:null},“name”:“”,“onlyChanges”:false,“x”:850,“y”:680,“wires”:},{“id”:“387fb997123921d3”,“type”:“delay”,“z”:“f9b7078128f9a26d”,“name”:“”,“pauseType”:“delay”,“timeout”:“.1”,“timeoutUnits”:“seconds”,“rate”:“1”,“nbRateUnits”:“1”,“rateUnits”:“second”,“randomFirst”:“1”,“randomLast”:“5”,“randomUnits”:“seconds”,“drop”:false,“allowrate”:false,“outputs”:1,“x”:280,“y”:320,“wires”:[[“3dc5d1252704f8a3”,“9f3fbd58af4317a6”]]}]
