Is it possible to simply add the Large version of the version installed on our Cerbos without upgrading to the latest version of Venus?
You probably need to download the large image from the pro site and then update it manually.
Haven’t tested it myself, but just selecting the large option image type might just use the version you are on.
Okay, thanks for the feedback @nickdb
Has anyone tried this before?
I did once go back to the small image but can’t recall if a newer build was available.
Remember it is easy to rollback to backup versions.
Manual updates are straightforward as well.
My version is no longer available v3.53 , what should I do? Is there another repository for older OS that I still want? ![]()
I found it here
