I have four tanks with senders on my vessel. 3 are N2K senders and one is a traditional resistive sender. For the 3 N2k senders, when I go to can-bus and Device the Custom Name field is not editable. So my tanks show up with device instance info on the display (see image). Through the facebook group it was suggested I edit this field using the Victron Connect app. When I try that, the field is editable but the value does not save. Is it possible to set the name for tanks being shown through canbus?
In short, the custom name field works fine for any analog devices connected to the GX but does not seem to work for any device connected via the can-bus.
