A year ago, I noticed that the solar controllers no longer functioned correctly after updating to the latest firmware.
Now, since I added a battery to my system, I also updated the firmware for the solar controllers to V3.16.
Then only one of the 7 SmartSolar controllers connected via Can was still working. Finally, I updated the GX device in my MultiGx to the latest version (3.51). Unfortunately without success. The behaviour remains the same.
Unfortunately, my account has also been deleted in the meantime and I had to register again.
So the only solution is the same as a year ago: downgrade to V3.13 ;-(
V3.13 yesterday, V3.16 today
Because I was already there, I tested version 3.15 straight away: It works “just as not” as version 3.16. Now I have all solar controllers running on V3.13 again and it works perfectly.
My system is now running:
Multi2GX V3.51
1x SmartSolar_MPPT_VE.Can_150_70_rev2_v3.13_A10C
2x SmartSolar_MPPT_VE.Can_250_70_rev2_v3.13_A114
4x SmartSolar_MPPT_VE.Can_250_85_rev2_v3.13_A116
When can I expect a correction to the latest version so that I can also benefit from the improvements in the updates?
Until now I had assumed that the VictronComunity was supposed to be a knowledge base for all Victron users and therefore wrote the questions and problems in English.
However, with the changeover to the “new” system, my account has now been deleted and with it all chat histories. This means that I can no longer understand how to solve a problem myself, even if I have had it before.
Is it possible to get the chat as an export? There were a lot of interesting topics there that I would like to access if necessary.
Thanks for your help!
