The easiest way to connect your GX devices to Home Assistant
There are many tutorials about how to connect Cerbo GX (or other GX devices) to Home Assistant using the MQTT protocol. They all gravitate around installing MQTT addon on your Home Assistant server and connecting it to the Cerbo GX MQTT server. That is lot of work.
I created much simpler solution using custom integration. It requires zero configuration as it auto detect the Cerbo GX devices and do all the connectivity for you. You can find it here. I would paste a link to the GitHub page but it seems to be blocked.
Any feedback will be appreciate. You can open an issue on the GitHub page.
The project seems to be gone. Is it posted somewhere else now?
