Target SOC
I have have a Multi RS (1 Tracker) and a Cerbo GX. Both have the latest Firmware.
If I activate the Dynamic ESS over the VRM, I get a new menu in ther Cerbox UI (Remote Control) and it shows “Target SOC --%” but I can’t change the Target SOC there.
Is there a way to change the Target SOC? Or is there a other way like over MQTT?
Thanks Jan
That’s the target which is calculated by DESS. You can’t change this.
Just read the DESS manual :wink:
Thanks for the reply.
I have right now the DESS running for about 2 weeks and the Target SOC is still the same (–%). And my Batteries are not charging. When the Target SOC will be calculated?
Hereby my DESS settings:
Thanks Jan
“–” is normal value in some situations
But you always can have a look at the planned target SOC in VRM, for example my sytem today:
Maybe your battery costs 0,03 kr/kWh are too high?
Edit: but no, this are only 0,0026 EUR/kWh. Thats definitely not too high
I just switched the Battery coast to zero. I will see what it will do the DESS
Hereby my system:
Is there something what I can check to fix it?
I think that the system needs to learn the houshold electrical habits first before it can do a good job.
