The solution I proposed above is great if it is to always keep the AC input current limit at the same value (and this value being lower than the minimum configurable value when Power Assist is enabled). But it is an impractical solution if you need to change the configured limit, because you will need to do it through VE Configure, enabling or disabling PowerAssist, inserting or removing the assistants and changing the AC load value in the assistants that causes the AC input to be ignored. A better, much more practical solution would be to automate all of this through Node Red, configuring everything according to the current limit set by the console. I tried to do this, but I encountered a difficulty: when Power Assist is enabled, and a current limit value is entered through the console that is lower than the minimum acceptable value when Power Assist is enabled, the value entered is automatically replaced by the minimum value, and I cannot get the value that was entered in Node Red to be able to disable Power Assist. I talked about this in this other post, let’s see if a solution appears for this.
vcleto
(Valdson)
19
Related topics
| Topic | Replies | Views | Activity | |
| Node-RED flow to set low current limit on AC input | 4 | 596 | 29 March 2026 | |
| Nodered - multiplus2 - charger current limit | 13 | 926 | 21 September 2025 | |
| ESS limit (dis)charge power in watts | 9 | 291 | 5 February 2026 | |
| DVCC activated (v3.70), noESS: Limit Grid charging (trough Multiplus2) in a flexible way - how? | 12 | 371 | 14 June 2026 | |
| Get the current limit value at the AC input entered by the console | 1 | 116 | 24 June 2025 |
