Strange sorting order
From Latest posts. But this is not important.
Click on Views to sort on that. Strange results on that column…
Click on Activity to sort on that. Strange results on that column…
See below.
It seems that the last two column titles are shifted one position left. See last picture.
3
Maybe you wanted to also show the number of likes and you’ve missed that column title ?..
If this is true, please add the Likes column title.
I’ve saw that if you add at the end of the url the “likes” key, it works and it sorts on Likes.
Ironically, this is a bug that was linked to your other issue -Still under construction? - #2 by guystewart
Disabling the author column has fixed this.
:+1:
And the answer is the same as in the other issue: Still under construction? - #3 by alexpescaru
:smile:
