Have 2 10k Quattro in Split-Phase config, Grid meter, as the input of inverters are breaker from main panel house, essential loads are the Shop.
The house does use some power for well pump, pool pump and such at night, i have ess Assistant installed and have only ever seen L1 Invert, which is the “master” inverter. L2 never inverts when grid is available. Im not sure why its not doing both, L2 is Charging only it appears, but in LOM They will go into full invert mode, but not fast enough to maintain computers staying on, Partially feel its due to l2 not being able to invert with mains on.
Is there a setting im missing or a firmware issue, is there a stable firmware to fall back to?
