Solaredge communication dropping every few minutes
Hello all
i have make a script for solar edge via node red
script is complete you need only set the solaredge rs485 tot solar edge leader ant set id to 2 ant if you have ohter solaredge set id to 3 ant modbus to 502
version 0.01 test works for me next version pv limit addind whits ess
let me know if there are bugs
see script
you can import the scrip in node red
Hier is een nieuwe complete import-flow (1 tab) die het zeker werkend maakt, zónder meter-blok gedoe:
:white_check_mark: 2× SolarEdge (INV1 via 18fdf7679413493c unitid 2, INV2 via 0496ace946808635 unitid 3)
:white_check_mark: Leest alleen 40070 / 27 regs (SunSpec inverter model)
:white_check_mark: Berekent per fase Watt via V(AN/BN/CN) × I(A/B/C)
:white_check_mark: Totaal = som van 3 fases, en daarna INV1 + INV2 samen
:white_check_mark: Lifetime kWh = INV1 + INV2 (exact uit WH hi/lo + WH_SF)
:white_check_mark: StatusCode: 2 = running als totaal > 50W, anders 1 = sleep
:white_check_mark: Poll is netjes (1s) en leest om en om → minder “Close timed out”
Import: Node-RED → Menu → Import → Clipboard → plak → Import → Deploy
you need to set the ip from you omformers in INV1 ant 2 if you have 2 solaredge
if you have 1 need only INV1
Solaredge 2 omvormers uitlezen Victron Node Red.txt (9,5 KB)
