Solar goes to grid instead to battery
A third of the total solar power was sent to the grid, instead charging the battery.
System is in green mode. Feed in to grid is enabled. If I disable feed in to grid, then the excess is also not feed in, for which i get a small amount of money.
Found the Link to to the DESS HACK and will see if I can install it
Yes, the HACK should solve this problem!
Is installed :slight_smile:
